by aspencat2000 Investigator
Mobile data in iphone X doesn't work
Hi this is my day 3 with ee. Wifi is working but data is not. I've deleted profiles, turned it off and on, and when I that link (http://add-on.ee.co.uk/status), it says no problems....
Please help!!
6 REPLIES 6
Re: Mobile data in iphone X doesn't work
I also Reset Network settings...
@aspencat2000  If you text  BALANCE to 150 what message do you get back ?
Are you a contract or PAYG customer?
It says:
Your current balance as of today 10:42 is £0.00. You have 96 minutes, unlimited texts and 2.0GB remaining until 16/08/2019 for your £10 Data Pack. Your remaining data includes of rolled over data. For more info on your packs, add-ons or free boosts, go to MyEE. ee.co.uk/myee
For info on our other Text Services, reply HELP or go to ee.co.uk/textservices
It’s a PAYG account
@aspencat2000   Is this on all apps or only some ?  Can you use Safari at all ?  Is cellular data enabled if you open control centre? Have you allowed these apps to use cellular data ?
It’s all apps. Data is enabled...
Hi there @aspencat2000
Thanks for coming here.
What happens when you try and access any apps or Safari?
Are you in the UK at the moment?
Leanne 🙂
