by rocky66 Investigator
Mobile data consumption
My monthly 10GB data allowance is used up really quickly without me knowingly using data hungry applications such as streaming. Is there a way of seeing which iPhone apps are using up the data?
by Ace Contributor
Solution
Re: Mobile data consumption
Although you cannot see the monthly mobile data consumption, you can still see which app had used the most data.
You can check this by:
Settings -> Mobile Data,
Then scroll down, until you can see a list of apps there with their mobile data consumption to date.
W
by Ace Contributor
Solution
W
