by aaronkalirai Investigator
Mobile Signal Booster Box Port Forwarding
We have ordered 2 Signal booster Boxes for our offices as we're in the middle of nowhere and get poor signal.
These boxes however do nothing. They just flash as if they are awaiting activation, although i've already called and activated them.
I believe our firewall may be blocking them.
What ports are required to make these boxes work?
Don't say add to DMZ/Enable uPnP as they are not options with our Clavister Firewall.
11 REPLIES 11
by Star Contributor
Star Contributor
Re: Mobile Signal Booster Box Port Forwarding
Hi @aaronkalirai
Can you try holding a pin into the reset button then give it 10-20 minutes then check plesae?
Thanks,
Martyn
I've already tried this upon no success.
EE Employee
Hi and welcome to the Community @aaronkalirai
So I can assist, please may I know if you are using an EE personal or business account for your mobiles?
In the mean time have you popped over to the Clavister Forums to see if they can assist with locating DMZ etc.
Many thanks,
Lee
What Broadband are you connecting them to?
We are using an EE Business account for our mobiles.
Yes I have. There is no DMZ the only way around is to open ALL ports for a particular IP.
@XRaySpeX I believe we are using BT Broadband
EE Employee
Good Morning @aaronkalirai
It can take 24-48 hours for signal boxes to fully register.
Do you get at least 1 bar of 3G mobile signal in your office?
Do you know your broadband speed?
Thanks - Karen. Smiley Happy
@Karen_C
I left it turned on over the whole christmas period which is more than 24-48 hours.
I believe we get 1-2 bars 3G mobile signal. I'm in France atm so will have to double check when back in office on Monday.
We get around 45 Mbps Download and around 40 Mbps Upload speed. Ping is normally around 7
by Star Contributor
Star Contributor
@Karen_C
Are you thinking the cel-fi device is the solution?
Thanks,
Martyn
EE Employee
Hi @aaronkalirai
That's certainly long enough!
Every sounds fine with both signal strength and BB speed.
Did you purchase the signal boxes direct from EE?
@martyn413 I thought the signal may have been too weak for the signal box.
by Star Contributor
Star Contributor
@Karen_C
I don't think signal boxes need any signal to work as they use your bb connection.
The only legal booster is a cel-fi device which are so expensive.  The only need 1 bar of 3G then can boost it to 5 bars.
Thanks,
Martyn
