Highlighted
by Investigator
Mobile Data Public IP Address
Hi, I'm just wondering if anyone could give me any information about how public IP adresses are assigned when connected to mobile data.
Do they change after a set period? Can you force an IP change? or do you maintain the same public IP forever?
Thanks in advance
Highlighted
Solution
Re: Mobile Data Public IP Address
You can be given a changed public IP addy at any time. Not only that but it's not unique to you.
The EE mobile network uses Carrier Grade NAT (CGNAT), which means that you don't get your own public IP address but share it with other users. So you can't be uniquely id'ed on the Net & therefore your LAN cannot be addressed from outside for unsolicited accesses. This is unlike fixed BB.
Highlighted
Solution
Highlighted
by Investigator
Thanks for the info.
I can see mine has been updated now since I made the post.
The reason for asking is because I've been using my mobile data to hotspot my laptop and a site I've been using had restricted the last IP.
Does this mean everyone on that selected address would also be restricted?
Or is there a way for websites to differentiate between users connecing from the same public address?
Highlighted
Yes, everyone on that IP will be affected. There is nowt for an external site to distinguish them.
Try rebooting your router, but not too often, to get a new IP.
Highlighted
by Investigator
Unfortunately I'm with virgin media for my broadband who have notoriously sticky IP's.
Any idea how many people can share the same IP at once?
Highlighted
Sorry, I was talking about your mobile device which I presumed was a mobile router but could well be a phone.
I'm guessing up to 254 users with the same public IP. You can see your public IP at any of the "What's My IP?" sites but if you look at your phone's Status you will find another, private, IP addy probably of the form 10.x.y.z. This is the private IP EE gives you under its CGNAT to distinguish you from all the others on the same public IP. I'm assuming EE is using a subnet mask of 255.255.255.0 with these private IPs. So only the last octet, z, id's you.
