by thebizz1979 Investigator
Mifi problems TP-Link M7650
I purchased a mifi device earlier this week and I can't get it to connect to the EE network on IPv4 despite changing the settings.  The only work around is to change the setting from ipv4 to Ipv4 and Ipv6 and remove username and password in the settings, but these means Java will not load and I have other issues with other sites, and remote access to work.
I've had a good look on the forum and see that other people have had similar issues with other devices, I was hoping that some maybe able to assist me.
I'm on the Data Sim max plan.
11 REPLIES 11
Re: Mifi problems TP-Link M7650
Dunno if it's related but there seems to be issues affecting  CCTVs, security cameras & other sites intended to be viewed over the Net. It's probably down to EE employing IPv6 and/or CGNAT (Carrier-grade NAT) in its network.
Hi @thebizz1979
Please have a look here as there are some other users sharing information in this topic.
Thank you
Richard
Thanks for the replying I've had a go at trying the various solutions and I've had no joy at all.  I just can't get the mobile router to connect to IPv4 no matter what I do.  Anyone else got anymore ideas?
Good Morning @thebizz1979
Thanks for trying.
In this case please give us a call and will see what we can do to help.
Thanks, Leanne.
Called made and advised there is nothing that EE can do, because I am in contract I have to pay until it expires.  If I cancel now I lose my £10 a month loyalty which basically costs me twice as much.  I feel like they would be trying to do more if I was out of contract but I guess there is no inventive to sort it out if they can still get my money.
The most frustrating thing is that I don't actually want to leave EE - but I don't see why I should carry on paying for a service that I can't use!!  To say I am frustrated about this is an understatement!!
EE Employee
Hi @thebizz1979 and welcome to the community.
Have you been over to the TP-Link support pages to see if there is any help there?
Many thanks,
Lee
Hi Lee,
Yes, I've been through to there technical support team too.  I've also searched net to try and find a solution.
I've also tried couple of other networks sims in the device and they work.  The problem seems to be a conflict between EE's network and the device.  Looking through these forums a number other devices also have issues and it appears to relate to IPv4 following EE's updates.
Hi Lee,
Thanks for trying and for the update, @thebizz1979.
I recommend speaking to the technical support team again to give them this new information.
It may help them narrow down what's causing the issue and find a fix for you.
by stevef007
New Member
After several hours tearing my hair out, there is a solution.
The default profile setup on the TP-LINK m7650 is to use CHAP authentication.  EE installs a dial-up profile with the right login details and APN but doesn't change the default Authentication type to PAP. Create a new profile with the following settings:
Name: EE1    <-- call it anything you like
PDP Type: IPv4 & IPv6
APN Type: Static
APN: everywhere  <-- this is unique to EE and must be set
Authentication Type: PAP   <--- this is the default you must change
Username: eesecure  <-- this is unique to EE and must be set
Password: secure <-- this is unique to EE and must be set
Push Save and the MiFi will restart and presto 4G LTE network speed...
by ecoutez
New Member
I registered to thank you for this post. I was having lousy speeds and connections with the M7650 and EE until I found your fix. It works much better now (the odd drop out but not often) and is a permanent portable wifi in my bag, Thanks!
