by CharSand93
New Member
Maxx plan disappeared from my plan, why?
So my agreement was a 4G Maxx plan meaning I should be able to upgrade each 12 months instead of every 24 months, I’ve just looked on my plan now and it has disappeared, why is this?
Re: Maxx plan disappeared from my plan, why?
Hi @CharSand93
Unless you have upgraded then you will be on the same plan. If you are concerned this isn't the case then call CS on 150.
Hi @CharSand93,
That's great advice from @Northerner . If you took out an annual upgrade or upgrade anytime plan when you last upgraded, you'll still be on that plan.
