by LolaMitch2018
Just bought travel data package for USA but how do I use it
Just bought travel data package to use maps etc in USA. How do I use it as nothing happened I try to use maps but do I put data roaming on as it’s just swirling & timing out.
Re: Just bought travel data package for USA but how do I use it
You must have Data Roaming ON on your phone when trying to use data abroad. Did you check you had roaming enabled on your a/c before you left UK?
by LolaMitch2018
Do it need data roaming on to use my travel data pass in USA
Re: Do it need data roaming on to use my travel data pass in USA
@LolaMitch2018: There is no need to repeat your Q. I've already answered you here.
EE Community Team
Hi @LolaMitch2018,
Welcome to the community 🙂
Did you text  'ROAMING' to 150, to activate your account settings before you left the UK?
What phone are you using? you can check your roaming settings to ensure your device is correctly set up for when you are abroad.
Is it only your data that is effected? are you able to make and receive calls and texts?
Where in the USA have you gone? New York is my favourite place.
Alex
