by neildrummond3
Issues with iPad pro mobile data setup for the first time?
Anyone had issues with pay as you go on an ipad pro with the apple sim - topped up account with credit card no issues but as soon as I select the data add on - error is unable to purchase pass - any help would be appreciated
by Ace Contributor
Re: Issues with iPad pro mobile data setup for the first time?
Hello @neildrummond3 try restarting the device then trying again. You can perform a network reset by tapping>settings>general>reset>reset network settings (clears any saved Wi-Fi passwords).
Hi @neildrummond3
Thanks for coming to community 🙂
What is the error message you are getting?
The advice @tm90 has given you, have you tried it?
Thank you
Richard
by neildrummond3
Hi thanks for the reply’s yes reset the network settings - made no difference at all
Error is unable to purchase pass
[4EFE8239-1285-467B-96C6-FC3FC0FA0D5C.png]
by Ace Contributor
I am sorry that did not work. Customer service will need to access the account to check why you are unable to purchase a data add on then:
http://ee.co.uk/help/get-in-touch
Hi @neildrummond3,
That's great advice from @tm90, please get in touch with customer services so we can take a quick look at your account.
Recent solutions
