by Trush12
Isit free to use mobile data in Iceland?
Solution
Re: Isit free to use mobile data in Iceland?
Hi @Trush12
Welcome to the community. 🙂
Yes, as @sebastiandm said, you will be able to use your normal allowances in Iceland.
Please make sure you text ROAMING to 150 before you go. Just to make sure you're set up for international roaming.
Have a brilliant trip. 🙂
by Prodigious Contributor
Solution
Hi @Trush12
It's brilliant to see you helping others in the community, @sebastiandm.
In fact, as a thank you for being so helpful, I'd love to send you a small gift from the EE Community team. 🙂
I've sent you a private message requesting your details so that I can send you out a £25 Amazon voucher.
Please reply to the message with your details.
Chris 🙂
