by lemadelta89
New Member
Is there a way I can see a breakdown of my data usage?
I seem to have used most of my data in 8 days and i am not sure how, is there a way I can see a more detailed breakdown of what is was used for?
Re: Is there a way I can see a breakdown of my data usage?
Depends on your phone but normally there is a data app under settings which tells you how much you have used and what apps have used data.
This is the only way you can tell.
Make sure you've set it up to:
  • Only Update Software over WiFi.
  • Restrict Background Data.
