by scotty319 Investigator
Is the iPhone 8 Plus compatible with 300Mbps speeds?
Hi there!
I'm considering the iPhone 8, but here's a bit of a technical one. I know the iPhone 8 Plus will work with EE's 4G+ network.
But... is it compatible with the fastest speeds?
For a while, I had a Samsung S8. Using the speedtest.net app, I managed to get speeds of around 270Mbps. That's not possible with my iPhone 7. The fastest I've seen on it, is around 150Mbps.
I was just wondering, is the iPhone 8 compatible with those speeds? So could I see it hit 270Mbps (or whatever) on an iPhone 8?
Thank you 🙂
Re: Is the iPhone 8 Plus compatible with 300Mbps speeds?
Hi @scotty319
You're correct, the iPhone 8 Plus is compatible with 4G+ speeds.
The data speed depends on numerous factors, including (but not limited to) location, the number of EE users connected to the network in your area and your price plan.
If you take choose to upgrade online or over the phone, you will have a 14 day cooling off period. If you're not happy with the speeds, you're able to return the device. 🙂
Hope this helps.
by Star Contributor
Star Contributor
As Christopher has said, the iPhone 8 series is compatible with such speeds... And more!
