by Davie1986
Is my data included while in usa. Im on 4gee max 8gb june 2017
Hi all
Im heading to las vegas today and only realised that my data over there maybe included i  my plan. I have the 4gee max 8gb plan and i took it out in June 2017. I think my data should be included but id like clarification!
by Ace Contributor
Solution
Re: Is my data included while in usa. Im on 4gee max 8gb june 2017
Hello @Davie1986 yes USA roaming is included in all MAX plans taken out on or after 10th May 2017:
https://community.ee.co.uk/t5/Roaming/Using-your-EE-allowance-when-Roaming/td-p/567933
Make sure roaming is enabled on your account at least 24-48hrs before traveling by texting the code ROAMING to 150:
https://community.ee.co.uk/t5/Roaming/EE-roaming-Getting-ready-to-use-your-phone-abroad/td-p/532570
by Ace Contributor
Solution
Hi @Davie1986
Thanks for stopping by community 🙂
The information @tm90 has directed you to, are the exact pages you need to look at.
Don't forget to set up Roaming and make sure it's activated.
Have an amazing time in Vegas, many people tell me I look like Alan from the hangover.  Also one last tip, make sure their are no Tigers in your bathroom.
If you haven't seen the film (this will be lost on you) ha ha
Cheers
Richard
Recent solutions
