by Dickyboy82
Iptv problem
Recently my iptv won't work on my Google pixel 2 phone. When I first had the phone it worked nicely and now it will load but soon as I select to play anything it won't play at all.
Is there any settings I need to alter in the phone??
Do ee block some services?? I phoned the customer services and they told me ee don't block any apps or servers.
Any help much appreciated
Re: Iptv problem
Hi @Dickyboy82,
Welcome to the EE Community.
Which app are you having problems with?
Are any other apps affected?
