by Bluepeg548 Investigator
Internet connection
Hi...I can't connect to the internet away from home. I have a samsung galaxy A5 2017 on EE. I'm fine at home via Wi-Fi or any other Wi-Fi. Just wondering if anyone has settings I can check with mine. Thanks
by Ace Contributor
Solution
Re: Internet connection
Hello.
Please try to reset your Internet settings. click here Internet - EE Setup,
Find your phone model and send Internet settings on your phone install them,
hopefully it will work for you,
7 REPLIES 7
by Ace Contributor
Solution
Hello.
Thank you. I will try that and let you know 😊
by Ace Contributor
Hi, @Bluepeg548
Hopefully it work for you,
cheers
Thank you Tahirmian, normal service is resumed! Thank you so much for replying. 😊 Ann-Marie
by Ace Contributor
You are most welcome,
Hi @Bluepeg548
Welcome to the EE Community.
I'm delighted to see that @tahirmian was able to help you get your internet connected. 🙂
I hope to see you around here again soon.
Chris 🙂
Thank you. I was confident I would find the answer I  here 👍
Ann-Marie
