by andrewmartin Investigator
Internet connection by 3G router
Hello to everybody,
i got as new SIM and want to use it in a 3G router (Onyx Mobile Smart Center).
In the configuration of the router i am asked for the configuration. I tried:
Kind of connection: 3G
Config mode: auto
Number to dial: *99***1#
Username: user
Password: pass
APN: general.t-mobile.uk
is this correct?
Best regards Andrew
Solution
Re: How to configure a 3G router (Onyx Mobile Smart Center)
Thanks to everybody!
I connected another device successfully to the router and it worked from the beginning on :0)
Since erasing the wifi- connection on the first device and reconfigure it again it also works on that one.
Thanks a lot
Andrew
6 REPLIES 6
Hello to everybody,
Config mode: auto
Username: user
Password: pass
is this correct?
Best regards Andrew
sorry, i just recognize that my first intent to ask you already was successfull =8-(
sorry for that!
by Star Contributor
Star Contributor
Re: Internet connection by 3G router
APN: everywhere
Often don't need a username and password, otherwise 'ee secure' and 'secure' respectively.
Never come across a number to dial so can probably leave that.
EE Employee
Hi @andrewmartin and welcome to the community.
I'm glad you are now sorted 🙂
Many thanks,
Lee
Solution
Thanks a lot
Andrew
Thanks for the update @andrewmartin Smiley Happy
I'm happy to hear you got it working.
