by Gamesboard Investigator
Instagram and more
Hi
From couple of days my internet seems not to work properly it's really slowly everything takes long to load, YouTube videos takes ages and comes with low res...Instagram doesn't load AT ALL. I have biggest plan with 25 GB of data and 4GEE. It didn't happend before. I checked YouTube and Instagram via Wi-Fi and everything works perfect. Do you have some problems there? And it's not only at my home or work it's no matter where I am just doesn't load 😐
EE Employee
Solution
Re: Instagram and more
Hi @Gamesboard,
Soon as we have any details in regards to a fix we will certainly let you know.
Many thanks,
Lee
6 REPLIES 6
Hi @Gamesboard,
Welcome to the EE Community. Smiley Happy
Can you see any issues in your area on the network status checker?
No Sir everything is fine in my area,
as I did mention at the end it's no matter where I am it's still the same. ( it's not application fault or my phone cause through Wi-Fi everything works just perfect and my phone is fresh as I got it just last month from EE)
Hi @Gamesboard,
Thanks for checking, we've had a few other customers report a similar issue and our networks team are currently investigating.
We'll keep you updated.
Okay mate...I hope you fix it asap cause I paying almost £50 for my plan and I can't use it fully as I was when I had pay as u go for  £20.
EE Employee
Solution
Hi @Gamesboard,
Many thanks,
Lee
Good Afternoon @Gamesboard
This is now resolved 🙂
If you can try this and let me know how you get on?
Thanks 🙂
