by feeboes Investigator
Incorrect Data Allowance on New Plan
I have just bought a new sim only plan for 60 Gb of data. However on my account it states I am only allowed 30 Gb?? Where does the other 30Gb account for?
7 REPLIES 7
by Ace Contributor
Re: Incorrect Data Allowance on New Plan
Hi @feeboes,
Have you checked within the 'Add-ons' of My EE, some plans are built with a base allowance with additional through add-ons?
Thanks,
Peter
Hi there @feeboes
Let us know how you get on after checking your My EE account 🙂
Speak soon.
hello yes there are add ons in my account but I was not told this when I bought the sim card. I was made to believe I had 60Gb of data
Hi @feeboes
The add-ons that you have are these data add-ons?
If so, do you have 30GB showing?
Hello Leanne,
No they are not data add ons,
They are add ons like the 100% usage alert and calling abroad from UK
The only data showing I can see is 30Gb
Hi @feeboes.
If you can't see a data add-on anywhere on your account, I'd recommend contacting our Customer Care team to make sure that you're on the right plan.
Jon
