by HAYLEY96
Im using a samsung galaxy s6 . My data isnt working atall . Help ???
Im using a samsung galaxy s6 . My data isnt working at all ! . I had this problem before but when i called they said i ran out but i know i still have as ive also not had data turned on since i payed my last bill ... please help before i loose my mind 😭😭😭
Re: Im using a samsung galaxy s6 . My data isnt working atall . Help ???
If you have called CS and they said you have run out then either use wifi, buy more data or increase your tariff/data allowance.
Hi @HAYLEY96
Thanks for coming to community 🙂
I'd highly recommend having a look at our How much Internet data are you using on EE? support article.
If you think something has gone wrong then please get in touch with our technical team.
Thank you
Richard
