by Chewmyr00t Investigator
If i purchase additional data during a billimg period, why cant it carry over?
If i purchase additional data during a billing period, why can't it carry over? It's robbery!
Re: If i purchase additional data during a billimg period, why cant it carry ove
@Chewmyr00t  It states that it’s for a set period so you only purchase what you need to get you through to your next billing cycle.
Hi @Chewmyr00t
Welcome to the community. 🙂
As @Chris_B mentioned, there are different terms for each add-on.
If you select 'the important stuff' before purchasing, it will explain when the add-on can be used.
Hope this helps.
Recent solutions
