by chris3449
If I upgrade with SIM only plan, will I lose all the contacts on my SIM
If I upgrade with SIM only plan, will I lose all the contacts on my current SIM?
Re: If I upgrade with SIM only plan, will I lose all the contacts on my SIM
Depending on your current phone and if you have backed up your contacts then no you will not lose anything.
Thanks,
EE Employee
Hi @chris3449 and welcome to the Community.
If you are keeping the same SIM you will lose nothing as it is classed as a talkplan charge.
Many thanks,
Lee
