by Anyaa
New Member
I’ve recently put my SIM card in a different phone and now the 4G won’t work?
Re: I’ve recently put my SIM card in a different phone and now the 4G won’t work
Does this other phone actually support 4G or is it only 3G? What phone is it?
Hi @Anyaa
There is no real reason 4G wouldn't work just because you removed the SIM unless you have deactivated 4G/Data on the device or it may not be a 4G device.
What devices are you using?
Try removing the SIM again.
Morning @Anyaa
What phone are you using?
Does the 4G work in another phone?
Hope to hear back from you soon 🙂
