by PoKeYhAt
I use client VPN on my iPhone - works fine on wifi, doesnt work on 3G/4G mobile.
I'm using a Cisco Meraki client VPN (uses the native iPhone VPN client) - i can connect fine when i am connected to WiFi, when i switch to mobile, the connection times out. The vendor has asked me to verify that EE supports client VPN (I assume they do - would be ludicrous if they didn't) - can anyone confirm VPN is supported or offer any advice on how to solve this one? Many thanks!!
Re: I use client VPN on my iPhone - works fine on wifi, doesnt work on 3G/4G mob
Hi @PoKeYhAt.
Thanks for coming to the EE Community 🙂
EE don't block any VPN's on the mobile network.
I'd recommend asking the VPN provider if they support IPV6 over mobile networks.
Jon​​​​​​​
by PoKeYhAt
Thanks for the reply Jon - I’ve bounced it back to the provider re: IPv6 support....one fears the worst!
Let us know how you get on @PoKeYhAt
Thanks 🙂
