Highlighted
I need help. Data has run out 1st time as WiFi/phone has been playing up.help
Don’t think I should have to pay for new data as my WiFi connection has been poor it doesn’t connect to known networks and disconnects randomly when I connect it manually
Highlighted
Re: I need help. Data has run out 1st time as WiFi/phone has been playing up.hel
Hi @Deborah96
You don't want to pay for data because you are connected to a poor WiFi connection?
Are you also on EE broadband? What device do you have?
Highlighted
by Established Contributor
@Deborah96
a few questions to see if I can help:
- are you a long distance away from the router when trying to connect?
- if you stand next to the router and connect to the wi-fi, do you have max bars signal strength?
- as @Northerner asked, are you on EE broadband or a different ISP?
