by SMcG
I’m in Japan, have bought roaming data add on but it doesn’t work. Any advice?
Re: I’m in Japan, have bought roaming data add on but it doesn’t work. Any advic
@SMcG  Did you activate roaming on your account before you left the UK ?
by SMcG
I believe so but can’t be 100% sure - how can I check or get it activated so data does work? Is that something you can help with?
Sent from my iPhone
@SMcG  Have you enabled Data roaming on the device?  It’s under Settings>Mobike data>Mobile Data Options.  Toggle data roaming on.
Hello @SMcG
Thanks for posting on the community.
Has the advice from @Chris_B got the data working for you?
If not, can you make calls and send texts?
Hope you're having an amazing time in Japan 🙂
