by Heidiwood
I'm in France and I'm using my 4G, will I be charged?
Re: I'm in France and I'm using my 4G, will I be charged?
@Heidiwood  You can use your texts, minutes and data in the EU now.  You can use up to 15GB if your tariff has more than 15GB per month.  And you’ll not be charged any more then if you was in the UK.
by Ace Contributor
HI @Heidiwood
You can use UP to 15GB of your data allowance free while you in France .
by Heidiwood
Thank you! 😊
Morning @Heidiwood
Glad you got the help you needed from the community.
Have a great time in France 🙂
