by Priyaxsa
I haven't used my data very much, but its shown that I've used up 1.5GB of 2.
How can I recover it?
Re: I haven't used my data very much, but its shown that I've used up 1.5GB of 2
Check  your phone data app (normally under settings) and it should say what has used your data.
Unfortunately you cannot have it back if you have used it. You can buy more if needed or maybe use wifi.
Hi @Priyaxsa
Welcome to the community and thank you for joining 🙂
I can see that you have been helped by @Northerner already.  If you have WiFi then try and use it to protect your mobile data.
It may be worth looking at a new price plan.
If you are thinking to yourself that I want to change my EE price plan - what do I need to do?  see our support article.
Just to confirm when you have used your data, you can't get it back.
To try and prevent this happening again, please take a look at our How much Internet data are you using on EE? support article.
I hope this all helps.
Let us know if you need anything else.
Thank you
Richard
Try the settings for restricting background data & doing software update only over WiFi.
