Highlighted
by Investigator
I have topped up my data sim card but now need to apply that credit
Hi All,
I have 7 data simcards that I am using in non EE 4G routers, I have in the past had to top up the sim card online, called up and have the customer support team apply that top up to a data package.
Is there a way that I can do this myself as it is very time consuming to call up everytime I need to apply that credit to a data package. Its frustrating as I can see that the sim card has credite but it will not allow me to access the page to then apply that credit to a data package on the sim card.
Thanks.
17 REPLIES 17
Highlighted
Re: I have topped up my data sim card but now need to apply that credit
Yes, just browse to http://add-on.ee.co.uk/purchase & buy the data add-on you want from your topped-up credit.
Highlighted
by Investigator
Thank you for your response but it fails with a "no internet connection, please turn off WiFi and try again"
Whatever I try, I cannot get to this page, either using the 4G router or using an old EE osprey device, looks like I will need to give in and call EE.
Alex
Highlighted
Hi @SimbaCub,
Thanks for joining the EE Community.
What happens when you visit the link @XRaySpeX posted when connected to the device you want to purchase data for?
Highlighted
Using the Osprey login to it at http://192.168.1.1 as "admin"/"admin" & click on:
To check your remaining data     allowance or buy a new data     add-on, click here. (opens in a new window)
See if it works by that route?
Highlighted
I did mean when connected to the MBB device (it's actually the SIM you are buying data for).
Highlighted
by Investigator
Hi @James_B,
It says there is no internet connection, It just doest not route me throught to the page, if I connect via WiFi or cable to my 4G router or if I connect via WiFi or USB to the osprey device.
It just refuses to work.
Thanks for the reply
Highlighted
by Investigator
Hi @XRaySpeX,
It says the same thing, there is no interent connection..
Ah well, will have to try the old fasioned way.
Thanks.
Highlighted
If it keeps saying "No Internet connection", which mine doesn't when I'm connected to WiFi, have you looked inside the routers to see their Connection Status? It's sounds as if they are not connected to the EE mobile network.
Highlighted
by Investigator
The connection status is connected on all simcards via the router GUI and has EE details etc.
I have actually brought 7X 30 day rolling contract sim cards to use for the month.
Thanks for all your responses.
Highlighted
Hi @SimbaCub,
You should be able to open http://add-on.ee.co.uk/purchase when connected to your 4G router, even without an active data pack/add-on.
Please get in touch with technical support so we can look into this for you.
Highlighted
by Investigator
Thanks for the reply, like I mentioned above, it refuses to navigate to that page, I have taken a nother path now.
Highlighted
No problem @SimbaCub
Don't hesitate to let us know if you have any further questions.
Highlighted
With my PC directly connected by WiFi to my (credit-less & data-less) MBB router & no other WiFi around I can get up the add-on purchase page w/out any warning about turning off WiFi and VPN.
Can turn off all other WiFi in your home, bring the MBB router to the close proximity of your PC & connect to it over WiFi? Does http://add-on.ee.co.uk/purchase still ask you to turn off WiFi or does it now take you to the add-on purchase page?
Highlighted
Hello I have this exact message have turned off Wi-fi mobile 3G my iPhone and iPad Wi-fi in settings but it still won’t go through to the purchase page... wow this is very very frustrating as surely too-up should credit the sim whatever !!!
Highlighted
Hi @Alirev
Thanks for coming here.
You should be able to open http://add-on.ee.co.uk/purchase when connected to your 4G router, this should not show an error for you.
Please get in touch so we can look into this for you.
Highlighted
I am getting the error message about turning off Wi-fi (which I have) and on all other Wi-fi gadgets in my caravan but get the following message
[cid:a2befbd0-0dec-4d65-b352-9fda9487694d@eurprd06.prod.outlook.com]
Sent from my iPhone
Highlighted
Hi @Alirev
Thanks for coming back to me.
If you get in touch, we will be able to get this investigated for you.
Leanne 🙂
