by Andrea54 Investigator
I have no Mobile Data or network coverage, any ideas?
16 REPLIES 16
Re: I have no Mobile Data or network coverage, any ideas?
Hello there @Andrea54
What device are you using?
Do we have any problems showing on the EE network status checker for your area?
Speak soon, Leanne.
by Jennymartin1982 Investigator
My phone has just lost service too i have bars but saying emergency calls only!!!
Hello @Jennymartin1982
Thanks for posting on the community.
 Is there any network problems showing on the EE network status checker for your area?
What phone are you using?
Hi, its saying theres no issues. Am using the new samsung a5
Thanks @Jennymartin1982
When did you get the Samsung?
Did you get a new SIM card?
I got in july,i just had to put in my old sim. Im going on holidays tmo so really hoping its sorted. This happened about 6 weeks ago.. and after about 3 hours the service came back
Hi @Jennymartin1982
Have you tried restarting the phone?
Is anyone else with you on EE?
If so, do they have service?
No there on 02!yea ive re started it.. turned ito ff and on.. turned it to airplane mode. Shall i wait another few hrs and then maybe ring?
I have full bars at the min.. could it be the sim?
I have no bars at all, emergency calls only. it was fine 2 days ago. the mobile data tab is no longer usable either!
Hi @Jennymartin1982
Are you able to try the SIM in another phone at all?
This will help us to see if it's the SIM card.
Thanks.
Hi @Andrea54
Can you let me know the below, so I can help you with this 🙂
I cant find the plastic thing to put the sim.into my old phone. I will look foe it though.
Let me know how you get on @Jennymartin1982
You can pop into an EE store if you have one close and they can test this for you .
If this is your SIM, take photo ID with you such as a passport and the store will be able to replace this for you.
Thanks, Leanne 🙂
Thank you. My phone is a HUAWEI P smart.
Morning @Andrea54
Is this happening in all areas?
Have you restarted your Huawei?
Speak soon, Leanne.
