by Deb1231 Investigator
I have had no mobile data connection for over an hour now. Any ideas?
Hi, mobile data has been working fine up until around 10:20am but I now have no connection at all.  Are there any known issues in the Manchester area or is it more likely to be a technical issue with my phone? Thanks!
7 REPLIES 7
by Ace Contributor
Re: I have had no mobile data connection for over an hour now. Any ideas?
Hi @Deb1231
Have you tried turning it off and on again?
What does the network status checker say for your postcode? Any reported issues?
https://myaccount.ee.co.uk/networkchecker/checkservice
I have just turned it off and when I restarted, a awhatsapp message came through that had been sent at 10:45am but dropped off again now.
Thanks for the link!  No network issues!  😞
by Ace Contributor
@Deb1231  Is anyone else near you on EE? Are they having problems?
by Profile closed
Not applicable
Hi @Deb1231
Could be just a phantom "glitch" which might clear soon! 🤞
BustaCrabb
by Ace Contributor
As @Profile closed  it's possible it is just a small glitch in the EE matrix. If it doesn't come back soon, I'd say call EE and they can look at it in a bit more detail, it could be no one else has reported it yet.
Or if you're inside, pop outside and see if that helps, signal might be a bit better.
Hi @Deb1231
What device are you using?
Can you make calls and send texts?
Leanne 🙂
