Highlighted
I have forgotten my password to my mobile phone
Can not get into my phone tried several times with password that I had written desperate now!
Highlighted
Re: I have forgotten my password to my mobile phone
You mean the PIN Lock? Think you need your PUK to unlock it which you can find in your MyEE.
Highlighted
@Ma19dan  The password to get in to the device is only known to yourself and unfortunately there is no override feature as that would make the password pointless as anyone could open the device.  You need to remember it.
@XRaySpeX  Mobile devices can have passwords to unlock them  this is a security precaution to stop others from gaining access to that device.  Sim pin codes don’t allow over 3 attempts to use them as in this case 7 tries were used to unlock the device thus the only conclusion is that it’s not a sim pin that’s required but the device unlocked code as mentioned.
Highlighted
by Brilliant Contributor
If you can't remember the password or back up details then the only option you have is a factory reset.
Which will erase all data off the phone
BrendonH (Android Expert) Samsung Galaxy S10+ (Android 10/One UI 2.1)
Highlighted
Welcome to the community, @Ma19dan
I'm sorry to hear that you've forgotten your password and are locked out of your phone.
If you can't remember the password, you may need to factory reset the phone.
What kind of phone is it?
