by subodhs64
I have bought a unlocked note 8 from USA. Will it get 4G in the UK ?? Thanks
Hello there. I have purchased a Samsung galaxy Note 8 from Best Buy USA a few days back. Is the international version, 64GB, model is SM-N950U1.
I checked with the staff and they said it will work in the uK and almost any country. I have now come back to the UK and notice that it is getting LTE/ 3G and 2G. The web browsing and youtube etc,.. work fine and reasonably fast. I remember that my previous S7 edge used to show 4G. My network in the UK is EE.
My question is that are 4G and LTE the same ?. If not should i return the note 8 ? Or if the web browsing is good keep it. The return is within 2 weeks !! So I would appreciate some advise and guidance. Many thanks. Subodh
by Star Contributor
Star Contributor
Re: I have bought a unlocked note 8 from USA. Will it get 4G in the UK ?? Thanks
LTE is 4G indeed. It supports UK bands fine.
