by Eishman Investigator
I have been unable to get anything higher than Edge since arriving in Paris
Hi.
Since arriving in Paris earlier today I have been unable to get anything other than an Edge connection. I have tried switching to all other available networks and it's made no difference.
Is there something I need to do?
I have the Everything Pack pay-as-you-go package
12 REPLIES 12
Re: I have been unable to get anything higher than Edge since arriving in Paris
What phone do you have? If an iPhone then try resetting your network under settings.
Also EE arn't response for networks abroad.
EE Employee
Welcome to the community @Eishman
Have you made sure that your data roaming is turned on?
Also you could try turning 4G off.
Let us know if you need any further help!
Thanks - Karen. Smiley Happy
Hi Karen
Thanks so much. That worked. The phone was setup at one of your stores for this trip so I  assumed all the settings would have been checked. I  didn't realise there was a data roaming setting.
Sorted
Good morning @Eishman
Thanks for coming here again 🙂
I shall let @Karen_C the great news.
Enjoy Paris.
Thank you
Richard
Hi.
Apologies but I am still getting E(edge) only.
Anything else I can try?
Hi @Eishman
Thanks for coming back to me 🙂
Sorry that you have needed to with the same problem again though.
Have you by any chance seen our Roaming with EE - What to do if you're having problems abroad support article?
I'd advise to look at that, to see if any of the hints, tips and tricks could help you first.
Thank you
Richard
Hi
I have followed those steps. I have an android phone that is not capable of4g.
Still stuck on Edge
@Eishman  You might be in a place that doesn’t have a good if at all 3G signal.
Hi @Eishman,
@Chris_B could be correct.
Have you been travelling around the city or just been in one area?
Hi.
Yes. I have been traveling around the city.
Unfortunately the only difference is the strength of the Edge signal.
I get nothing faster than Edge
Thanks for coming back to us @Eishman
Are you able to try the SIM in some one else’s phone at all?
This could help us to see if this is the phone or SIM.
I understand if not 🙂
by noCGN Established Contributor
I would try to search for networks manually and see if the phone findes other networks and what bands 2G, 3G or 4G and try to log in manually into one of the other networks.
Restarting the phone sometimes helps.
Also check the Network mode is not set to 2G only, but LTE/WCDMA/GSM mode ....
I would expect that in Paris one of the operators would have 4G+
http://maps.mobileworldlive.com/network.php?cid=13&cname=France
