by claireallmark
I have a data sim and require the USSD code to use it, how do I find this out?
I am using the data sim in a raspberry pi and need the USSD code to connect
EE Employee
Re: I have a data sim and require the USSD code to use it, how do I find this ou
Hi @claireallmark and welcome to the community.
I am not familiar with USSD codes what is the need for this type of code?
Many thanks,
Lee​​​​​​​
by Expert Contributor
Expert Contributor
Unstructured Supplementary Service Data
In non technical terms it's a code that tells a network to do something (that's particular to that network). eg. A network might respond  *#147# with a message giving the number of the last caller. Also sometimes used to give account balance.
(In a bit more detail - a subset of MMI codes. Unlike the codes for setting diverts etc, USSD are not standardised and specific to the host network if supported at all.)
The OP would need to say what the code is needed for.
Hi @Techhead
Thank you for sharing this information.
In fact, as a thank you for sharing this, I'd love to send you a voucher.
I've sent over a private message, please reply to me with your details and I'll send it out as soon as possible.
Look forward to hearing from you.
Richard
