by 3sim
New Member
I have a 3 sim shared data plan but one of my sims doesn’t have data
I have a 3 sim data sharer plan but one of the sims keeps losing data
by Brilliant Contributor
Re: I have a 3 sim shared data plan but one of my sims doesn’t have data
Hello @3sim ,
Welcome to the community,
You say you have a 3 sim data plan but one of the sims does not have data. Do you actually mean you have 3 SIM cards or they are 3 SIM cards? If the latter, you will have to speak to 3.
If it is that you have 3 SIM cards with EE that should all have data, then it may be that one of them is faulty, need more information in order to help you.
Hi @3sim,
Is the SIM that loses data in a different location?
If so, does the Network Status Checker show any problems in the area?
Recent solutions
