Highlighted
New Member
I have 30gb data plan and am wondering how much I can use for tethering?
I have a 30gb data plan and am wondering what the limit is on tethering to other devices. And also what the (shared) means when I look at my plan.
thanks
Highlighted
by Profile closed
Not applicable
Re: I have 30gb data plan and am wondering how much I can use for tethering?
The only limit to tethering is your included data allowance.  If you have a 30Gb data allowance, you can tether upto that 30Gb allowance.
All plans used to be set up as sharer plans and then you could also add another shared line, however, EE no longer sell any shared plans now and have switched to data gifting instead.
Highlighted
EE Employee
Hi and welcome to the community @Scott2904
Hopefully the brilliant answer given above from @Profile closed has helped 🙂
Many thanks,
Lee
