by sonaki9412 Investigator
I can't get on 4G
Hi
I came in London in March as a student and I had contract with EE last month when my PAYG is last day. This contrcat include free underground wifi.
But i don't know why i can't get on 4g. They cover my location but i can't get on.
And also i can't use underground wifi. I bought this Sim card in Heathrow Airport, is this can be problem that i can't get on 4G and underground wifi?
My phone is Samsung Galxay 7.
No 4G, no underground wifi despite i had contract. sad...
EE Employee
Solution
Re: I can't get on 4G
Hi and welcome to the Community @sonaki9412
Please see our EE underground WIFI guide for help with setting this up.
In regards to your data, please do double check the settings
Name Internet
APN everywhere
Proxy Leave Blank
Port Leave Blank
Username Leave Blank
Password Leave Blank
Server Leave Blank
MMSC http://mms/
MMS Proxy 149.254.201.135
MMS Port 8080
MCC 234
MNC 30
Authentication Type PAP
APN Type If you have choices select internet + mms otherwise type in *
Hope this helps,
Lee
by Brilliant Contributor
This would not be a contract if purchased from Heathrow airport.
It would be pay as you go.
You won't get wifi on underground with this.
Regarding 4g have you got this enabled on your phone.
Settings > Mobile network > chrck the option for 4G/3G/2G or LTE... (auto connect)
by Ace Contributor
@sonaki9412
EE Pay as you go customers are eligible too WIFI ON THE LONDON UNDERGROUND
, as long as your account has been topped up with a minimum of £5 within the last 30 days. If your last top up took place more than 30 days ago, it can take up to two days from the date of your latest top up to update your account and provide you with access to the services.
And you can register by texting EEWiFi to 9527
And 4G you need to check your phone settings as @BrendonH told you.
I hope it will help you.
Many Thanks
EE Employee
Solution
Name Internet
APN everywhere
Proxy Leave Blank
Port Leave Blank
Server Leave Blank
MMSC http://mms/
MMS Port 8080
MCC 234
MNC 30
Hope this helps,
Lee
