by Princepalshimar
I can’t check my data how much left
by Ace Contributor
Re: I can’t check my data how much left
Hi @Princepalshimar
Welcome to the EE Community,
If you go to this link  http://add-on.ee.co.uk/ you should be able to check how much data you got left.
Thanks,
David.
by Princepalshimar
I would like to check my data
Re: I would like to check my data
Look at http://add-on.ee.co.uk/status when not connected to WiFi to see your data & credit status.
