by ZM0607 Investigator
I can't check in on social media
no locations found
Re: I can't check in on social media
@ZM0607 : Could be your Switching Content Lock OFF or ON . It is switched on on new & upgraded contracts & seems to affect social sites. If just switching it OFF doesn't help, try switching it to STRICT, reboot your device and then switching it to OFF. That is seeming to do the trick.
Hello @ZM0607
Thanks for coming here.
Can you try the steps @XRaySpeX has provided, does this now work for you?
Speak soon 🙂
Steps did not make a difference
Thank you for the advice however this did not work
Thanks for trying @ZM0607
What device are you using?
Can you view images on social media sites?
Leanne 🙂
