by judith448 Investigator
I can't access EE or 4G on my iphone
12 REPLIES 12
Re: I can't access EE or 4G on my iphone
@judith448  Have you tried restarting the device?
Yes, several times!
@judith448   Have you had a look at THIS to see if there is a network issue in your area ?
No known network problems.
It's an iphone 5S
@judith448  Can go to settings>General>Reset>Reset Network Setting.  The device will shut down and reboot on its own and you’ll also need to put your WiFi passwords back on the device after this.   You are performing a full network reset on the device and hopefully this will fix issue this for you.
Thank you for your help - its still searching at the moment!
No it hasn’t. Any other suggestions? I’m going on holiday tomorrow but at least WiFi is working.
That's cuz WiFi has nowt to do with EE's mobile network.
Hi @judith448
Welcome to the community.
I see @Chris_B has offered you some brilliant help to try and get your connection back.
Could you try all of the steps again this morning and let us know if it's any better?
