by Keith27120
New Member
I can not makes calls in the Netherlands.
Solution
Re: I can not makes calls in the Netherlands.
Hi @Keith27120
Log into your on line account and then Menu - Manage Device - make sure you have activated roaming and international calls.
Or
From the MyEE app Current Usage - Controls - activate use phone abroad and make international and premium calls
Solution
Hi @Keith27120
Or
Recent solutions
