by Josh108 Investigator
I bought a 13GB International data sim 3 days ago. I have only received 3GB.
6 REPLIES 6
Re: I bought a 13GB International data sim 3 days ago. I have only received 3GB.
Hi @Josh108
Where did you buy it?
Was it preloaded?
Screenshot_20190409-194101_Samsung Experience Home.jpgSystem notification
I bought it at the airport. I was told that the extra 10GB will automatically load.
I received a text that my data is almost used up.
My system sent me this notification.
Hi @Josh108
You need to use up the data which came with the SIM, then the bonus data will be applied.
Thank you for your help.
I've already finished the 3GB. I now don't have any mobile data. Need to connect via WiFi.
I've also tried texting LHR10 to 150.
Good Morning @Josh108
Thank you very much for confirming this.
I have sent you a private message for further information.
Speak soon,
Katie 🙂
Thank you everyone for your help.
I am terribly disappointed with this network.
I have resorted to using my home sim and roaming in the UK with that.
