by Lynseylou Established Contributor
Huge delay in connecting to Pokémon Go and Kik on mobile data
 Whenever I go from using my WiFi at home to using my mobile 4G data there's a huge delay in letting me connect to Pokémon Go and Kik. Everything else works (Facebook, Pinterest, WhatsApp, Email...). It says I have 4G and full signal.  Pokémon Go just won't load and neither will Kik. They do eventually but it's hours later which is really inconvenient especially when I've got limited time to use both.
I've got Samsung Galaxy S7edge and running Nougat. Thanks
by omawill Valued Contributor
Valued Contributor
Solution
Re: Huge delay in connecting to Pokémon Go and Kik on mobile data
Hi
To find out your S7's APN settings check out this
21 REPLIES 21
If everything else works on 4G when you come off wifi, then this seems to be an issue with those apps not EE network.
EE Employee
Hi @Lynseylou
Thanks for coming to the Community! Smiley Happy
Are both of the apps up to date?
If they are I would try deleting and re-installing them.
Thanks - Karen. Smiley Happy
Thank you for replying. They're both up to date and I've also uninstalled then reinstalled them both several times and factory reset my phone.  It hasn't helped unfortunately but thank you for your reply ☺️
EE Employee
No problem @Lynseylou
It's strange you're only having issues with these two apps.
What's your remaining storage like on your phone?
I did think this also it's just weird that it's two apps completely independent of each other. I'm wondering where else I could maybe get some answers.... 🤔🤔. Thank you for replying 🙂
Yes I agree. That's what's got me so baffled. They're completely independent of each other. I've tried restarting my phone, turning the WiFi off on my phone before leaving the house, turning phone off completely and turning it back on when I get to my location... Everything I can think of. I don't use WiFi away from home they just randomly start working again without me doing anything but not when I need it to! 😂. My storage and RAM is fine,  phone not rooted or any 3rd party stuff on it....
EE Employee
Hi @Lynseylou
They'll probably both have forums.
It might be worth popping on to see if anyone else is experiencing issues.
Have a lovely weekend!
by Brilliant Contributor
Pokemon Go take ages for me too on the Three network.
I would talk to Niantic. And whoever develops Kik.
Oh thank you! Got a link by any chance? It's not always, just when I initially go from WiFi to data... It's hours sometimes!!
Thank you flower. You too ❤️
CLICK HERE for Pokemon Go
CLICK HERE for Kik
Thank you so much! ☺️
EE Employee
Let us know how you get on @Lynseylou
Thanks - Karen. Smiley Very Happy
by ShaunHastings
Change your APN setting to IPv4 if it's not already, seems like IPv6 will not work correctly for some reason, I've had the same issue for almost 2 months and switching from IPv4/IPv6 to just IPv4 has fixed it.
Where would those settings be Shaun? I can't find them?
Valued Contributor
Solution
Hi
I found it but it won't let me change any of the settings...
Valued Contributor
Apologies, I am a heavy Apple user haha. I would assume it should let you change them, although I did read somewhere that EE didn't let you change the APN settings I think (a while ago).
I would agree with above posts, this seems more of an app issue although it is very strange it happened to more than one app, I experienced delays (not being able to access some apps at all) on the Three network. When I moved to EE all the issues went away.
It let me add it rather than change the existing one and it seems to have solved the problem! Thank you so much ☺️
