by PP1231
How to use data in France
Can I use my data in France with my current data pack, or do I need to buy add-ons? Is the step just text roaming to 150? And when I come back to the UK what should I do then?
Solution
Re: How to use data in France
Yes, it is part of EU. You may use your usual allowances there with up to 15 GB data per billing month if you have more.
Are you on contract or PAYG? If PAYG, you don't text ROAMING to 150; PAYG is auto enabled for roaming..
Solution
Morning @PP1231
Welcome to the community.
I can see you have had some great advice from @XRaySpeX
If you do have a pay monthly account, make sure you are set up to use your phone in France.
To do this log into your My EE account online go to Menu > Manage Device > Roaming Abroad and also Call Abroad and Premium rate> They will show as ticked if roaming and calling abroad is activated.
You won't need to do anything when you get back to the UK 🙂
Hope you have an amazing time.
by PP1231
Thank you. I use PAYG, so I don't need to do anything, right? both texting and setting up my phone.
That's right!
Hello @PP1231
You don't need to do anything to set up roaming, you will need to make sure you use your SIM in the UK before going abroad to make a call or send a text. 🙂
If you don't pick up a network when you arrive, you can manually connect to a network as below;
  • iPhone – Settings > Mobile Data > Network Selection > Turn off Automatic
  • Android – Settings > More Networks > Mobile Networks > Network Operators > Tap OK
  • Windows – Settings > Mobile Network > Network Selection > Tap on start manual search
Have a great time in France 🙂
Recent solutions
