by KB2
New Member
How much tethering allowance do I get?
I would like to know if I get a tethering allowance?
by Ace Contributor
Solution
Re: How much tethering allowance do I get?
Welcome @KB2. You can use your data allowance how you like, tethering, mobile data or a mix of both.
by Ace Contributor
Solution
Thanks for the great answer @chistery,
Let us know if you need anything further @KB2 🙂
