by Panchi Contributor
How many data addons can I buy a month ?
My monthly data has run out and I'm currently using an addon, but that also nearly ran out, so I went to buy another addon and it says you still have data left, will I be able to get another data addon once this one runs out?
by Ace Contributor
Solution
Re: How many data addons can I buy a month ?
Hello @Panchi you can purchase as many data add ons as you want but you can only purchase one at a time. When your current add on has expired or used up you can then purchase another one. 🙂
6 REPLIES 6
@Panchi  Yes you can,  you don’t need to wait for one data add on to run out before you purchase another one.
@Chris_B where can buy more data, there's no option on the my ee app and I cant buy some on add-on.ee.co.uk
by Ace Contributor
Solution
Hi @Panchi
I see the post above has been marked as a solution.
I hope everything is sorted with your add-on.
You can see more information on how data works with EE on our Manage your data on EE help and support page.
Recent solutions
