by AlanH10A
How do I turn Mobile data on. I have a Huawei 10
I seem unable to turn Mobile Data on. I go to Mobile data and then settings but can find nowhere to turn on. Help
by Ace Contributor
Solution
Re: How do I turn Mobile data on. I have a Huawei 10
Hi @AlanH10A
Please have a look at link below .
http://devicehelp.optus.com.au/huawei/p10-android-7-0/internet-and-data/turn-mobile-data-on-or-off/
I hope it will help you to sort this out.
by Ace Contributor
Solution
Hi @AlanH10A
by AlanH10A
Hi tahirmian, brilliant looks like you have solved my very annoying problem. Was stuck in 3 hour trafic jam today and could not work out how to get this turned on.
Many many thanks
Alan
Welcome to the community, @AlanH10A.
I'm glad that @tahirmian was able to help you get this sorted.
Chris 🙂
