by Sharongrimshaw
How do I transfer mobile data from my Samsung tab to my Samsung mobile phone?
Re: How do I transfer mobile data from my Samsung tab to my Samsung mobile phone
If you back up to either Samsung or Google, then use the same log on details on your phone it will transfer the backed up data over.
Hi @Sharongrimshaw,
Thanks for joining the EE Community.
That's great advice from @Northerner.
Please let us know if you need any help with backing up.
James​​​​​​​
by xiufu Contributor
I think we can use Samsung kies, Samsung Smart Switch or coolmuster mobile transfer to help us transfer mobile data from your Samsung tab to your Samsung mobile phone directly. About the details, you can check online. Just have a try and choose the one you like best.
