by Abby25987
How do I transfer data from one phone to another?
I'm wanting to transfer some data between phones and I can't find out how to do it?
Re: How do I transfer data from one phone to another?
HI @Abby25987
It would be helpful if you said which phones you have, and what you want to transfer.
You can normally back up online and then when you enter the same credentials on your new device the backed up data will download.
Thanks,
by Abby25987
I got sorted thanks. Found out I needed the app to do it
Sent from my Samsung Galaxy smartphone.
Hi @Abby25987,
Welcome to the EE Community.
Thanks for letting us know that you have found a solution.
Don't hesitate to let us know if you need help with anything else in the future.
