Highlighted
How do I top up my data sim
Hi everyone,
 I have an EE data sim which is in a router.  When I attempt to add this product to my EE account it wants to send a text message to verify the phone number.  Clearly, that's not possible in this case.  How can I get the sim registered to an EE account so that I can monitor its data usage and top it up when necessary?
Many thanks.
Highlighted
Re: How do I top up my data sim
@sugarat   The router can receive a text message and you can read it by login to the router via a web browser.  Go to http://192.168.1.1 with username/pwd of "admin/admin".
Highlighted
Hi Chris,
Thanks for that.  I suspected it would be able to.  I was about to ask if there is any other way to do it, as it means I would have to drive over to the site where it's at, however I just remembered that I'm probably going there tomorrow, so I can give that method a try.
Many thanks
