by Robegreenway65
How do I share data
Can anyone tell me how I share data step by step please
Solution
Re: How do I share data
Good Afternoon @Robegreenway65
Thanks for posting on the community
To use data gifting, you would need to be on the same pay monthly account.
If you are, can you follow the below steps;
  • Open your My EE app
  • Go to Family Usage
  • Select who needs data
  • Select the number you would like to gift data from (you will need at least 500MB of data left to be able to data gift)
  • Enter the amount you would like to gift
  • Send the data
Thanks 🙂
@Robegreenway65 : Are you all are on contract under the same MyEE family a/c, not PAYG. You need to be to gift data. See Gift Your Data and Set Controls .
Solution
  • Send the data
Thanks 🙂
